In the current version of the game manual, there are 182 mentions of ‘disc’ and 10 mentions of ‘disk’. All 10 mentions of ‘disk’ are in the field overview.
What are your guys opinions on this situation?
To settle this debate, I think we should call them “rings.”
Lack of imagination in the solution…
k
“Disk” is the american way to spell it and “disc” is the british way.
i think it is mobile goal. you can’t convince me otherwise
It is a pancake
I personally like disck.
It’s a cookie
(My sis teams mascot is Cookie Monster)
i call it A yellow foam object that can be manipulated by Robots and have the following overall
dimensions, with an expected tolerance of 0.02”:
• Diameter: 5.512” (140mm)”
• Thickness: 0.787” (20mm)”
• Weight: 65g ± 20g
Disc golf generally is spelled with a c and since this is essentially a robotic version of disc golf, it should be spelled “disc”. I do hope there is some official verification of that though, it could become a serious issue scoring matches if people are using different spellings for the same thing.
While this is technically correct, it goes a little deeper than that.
Disc with a -c is most commonly used for devices carrying sound, such as vinyl records, or a compact disc(CD, for those too young to remember). This is also used alternatively as those flat circular things we throw called ‘frisbees’, and as such, is the correct spelling in the context of Spin Up.
Disk with a -k is most commonly used in technology, one example being a hard disk.
But yes, if random tech knowledge isn’t your thing, just remember that frisbees are discs with a -c, because we see them flying into crowds when one’s autonomous fails miserably. :)
discs and rings are “similar”
shouldn’t this stand out from disc golf?
I guess I’ve never played disc golf where you throw a bunch of string everywhere at the end, so yeah, you’re probably right.
We should call them flapjacks, and rename catapults to flapjack flippers
